0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | I will be painting my generator and starter soon and would like suggestions on the type of paint to use. I have been using high temperature (1200 degree) gloos black enamel for other black engine parts. Will this work on the starter and generator as well? Thanks, Wada 1951 Chevy 3604 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The hi-temp paint will be just fine. In fact, that's what I used on my starter.
Bill Burmeister | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I would use radiator paint instead of high temp paint. The starter and generator do make heat, and they don't have much in the way of cooling. A thin coat of radiator paint lets the heat get out and should make them last longer. What ever you use, make sure the paint is as thin as you can make it.
