7 members (SWEET, Donf, rfs56trk, sron48, 78buckshot, Wickedbass, JW51), 60 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#124320 01/31/2007 2:40 AM
I will be painting my generator and starter soon and would like suggestions on the type of paint to use. I have been using high temperature (1200 degree) gloos black enamel for other black engine parts. Will this work on the starter and generator as well?
Thanks, Wada 1951 Chevy 3604
#124321 01/31/2007 3:27 AM
The hi-temp paint will be just fine. In fact, that's what I used on my starter.
Bill Burmeister
#124322 01/31/2007 10:57 PM
I would use radiator paint instead of high temp paint. The starter and generator do make heat, and they don't have much in the way of cooling. A thin coat of radiator paint lets the heat get out and should make them last longer. What ever you use, make sure the paint is as thin as you can make it.
Paint & Body Shop moderator
