4 members (37 GC, Otto Skorzeny, Shade Baby, Eisenholtz), 122 guests, and 2 robots.
Topics128,140
Posts1,056,776
Members48,454
#1242161 11/06/2017 1:28 AM
Hello guys,
Today, I bought my first "Big Bolt", a 52 Chevy. I have owned several half ton AD pickups over the past 30 years but this is my first 2 ton, and I have been wanting one for a while. I am wanting to learn from you all so I may post questions from time to time.
The biggest thing I am seeing is that there aren't a lot of part available for the bigger antique Chevy's unless some of the newer truck parts will inner-change.
I will attach some photos below.
Kevin.
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
Nice looking truck !!
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Good luck with parts - post want ads in the Swap meet - Stovebolt.com is probably your best bet.
That is a fine looking truck.
Do you have a purpose for the truck (not that one is needed)?
Thanks guys!
tclederman, no I don't really have a purpose, just wanted a bigger truck to play with. I will use it from time to to transport lumber and plywood from the local Lowes to our home!
Big Bolt Forum Moderator
sweet! I have 2 of the 2-tons. Mine are newer though. I have been able to find a lot of parts at Napa and Rock Auto for mine, at least wheel cylinder kits, brake hoses, drive shaft carrier bearing, and stuff like that. Not much from newer trucks will interchange, cab stuff (at least on the Task Force trucks) is all the same as the smaller trucks.
Mike
Thanks 69Cuda!
I appreciate that. I knew that the cabs are the same as the 1/2 and 3/4 ton trucks but that is about all I know so it's a learning process! I do like the 1963 292 engine that is in it!
Moderator
Moderator
2 Offline
Watch it Kevin!
Big Bolts can be addictive!
BTW, Great looking truck!
If you ever are around the Jeff City area, Let me know and I'll buy you lunch.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Looks like you found a nice one! Congrats!!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Very nice looking truck. Congrats and hope I will be able to provide input in the future as I too am learning about them,.
Originally Posted by 2-Ton
Watch it Kevin!
Don
Thanks Don!
Sounds good!
Thanks Rich!
Thank you!
Great looking truck, Congratulations
Great looking truck try Jim Carter they don't advertise it on their website but they have wheel bearings and stuff for the one and a half and two tons but you have to call to know
TENINE
Just got MY first big bolt, 1950 4400 cab n chassis.
Already started the restore to looking good it runs, drives n stops via e-brake
Tophat
San Tan Valley AZ
1950 4400
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
1952 3100 panel (newest one)
Queen Creek AZ
Welcome to Stovebolt.com, Tophat
Start a few more posts, maybe post a few photos, and tell us more about your truck and what plan do do with it.
That'll get you up to the "quota" that allows PMs, and use of the Swap Meet.
Very nice truck. I'd leave it just as it is. I wouldn't attempt to modernize it. What parts are you looking for, or should I say, what does it need ?
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Can you post or bucket a few more pics of The bed I’ve got a 50 version of that same truck but mines a ton and a half and I’m looking to build a bed for the back of it basically the same style as well I can see in the front view picture of your truck
Tophat
1950 4400
Resto to drive it
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
Queen Creek AZ
Tophat here
Bought this 1950 4400 at auction on a whim needed therapy project (boredom) So I got it home and decided that since it needed new floor and outside cab corners the easier thing would be to take cab off of frame so it could be done right. Found a shop local that could/would do it and so it started. I went slow and removed bits and pieces bagged and tagged packed into totes for later. Right now the truck is in chassis roller cab and sheet-metal have been dustless blasted A glass and water mixed blasting style primed and ready to go to the shop for a new floor and exterior cab corners. Everyone asked me what are you gonna do with it when you’re done “haven’t made up my mind” so that no immediate plans to do anything with it when I’m done other than keep it. Ordered all new seals and rubbers gaskets and miscellaneous missing parts already planned on putting bucket seats with the console in it as it had no seat. Since the floor I ordered, I ordered it without a seat riser but It came with a seat riser seperate so we’ll see maybe I will go back to Bench.
I’ll get photos up soon
Tophat
1950 4400
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
Queen Creek AZ
Tophat, instead of piggybacking onto someone else’s thread why not start your own? Much easier to keep up with different trucks. If you want to document your build go to the DITY forum which is a sub-forum in the Welcome Center. Thanks
NICE 52 truck! Congrats.
Professional Novice
