8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert), 94 guests, and 2 robots.
Topics128,052
Posts1,055,716
#124156 01/17/2007 2:47 AM
Junior Member
Junior Member
Any one know if they make a inner lower door patch panel for a 52 Chevy. I have a slight bit of rust through on mine. Thanks
Joe
#124157 01/17/2007 3:27 AM
hit the links page at top. almost all the parts guys have them
tom
I don't suffer from insanity, I enjoy every minute of it!
#124158 01/17/2007 3:28 AM
Anonymous
Unregistered
Anonymous
Unregistered
I used some sheet metal to repair that area on my doors. Just cut the rust out and welded in new metal. This was the area where the lower weatherstripping mounts. There are repair panels but unless you need to do the very bottom of the door you may be able to do what I did instead. I may have some pics I can send you it you need them
#124159 01/17/2007 5:48 AM
good luck with the fit. Much has been said about it....don't get me started grin
#124160 01/22/2007 5:27 PM
What is currently recommended to smooth the area after welding on the new panels? Lead or plastic filler?
Ridge dweller
#124161 01/22/2007 7:30 PM
For large flat areas like doors, plastic filler is the quickest, safest and easiest.
With the heat needed to do lead work, even the old body guys prefer to reserve it for those areas that have enough angles or curves to give them good resistance to warpage.
1949 "Heinz 57"
#124162 01/22/2007 9:17 PM
I believe most honestly you can make that part if you have access to a brake. Bend a 90+ piece 4 inches or more cut out and replace. Pics below
Dan
http://rides.webshots.com/photo/1512695955071274430lWhMwv
