| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 18 Junior Member | | Junior Member Joined: Nov 2006 Posts: 18 | Any one know if they make a inner lower door patch panel for a 52 Chevy. I have a slight bit of rust through on mine. Thanks
Joe | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | hit the links page at top. almost all the parts guys have them tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | I used some sheet metal to repair that area on my doors. Just cut the rust out and welded in new metal. This was the area where the lower weatherstripping mounts. There are repair panels but unless you need to do the very bottom of the door you may be able to do what I did instead. I may have some pics I can send you it you need them | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | good luck with the fit. Much has been said about it....don't get me started  | | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 | What is currently recommended to smooth the area after welding on the new panels? Lead or plastic filler?
Ridge dweller
| | | | | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 | For large flat areas like doors, plastic filler is the quickest, safest and easiest.
With the heat needed to do lead work, even the old body guys prefer to reserve it for those areas that have enough angles or curves to give them good resistance to warpage.
1949 "Heinz 57"
