| | | Forums66 Topics128,095 Posts1,056,475 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 7 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 7 | Need some direction in replacing the front bumper supports on my '50 1500. I see that the front spring shackles are part of the bolted up front. Was wondering about where and how to support things so that I can replace the front bumper supports without things falling apart on me.
| | | | | Joined: May 2015 Posts: 11,101 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,101 | What Brad said. Even though two of the bolts on each side go thru the front spring mounts, those are fastened to the frame independently. I just removed the broken up front bumper supports from my truck and it's sitting there on the wheels without any other support added.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
