| | | Forums66 Topics128,090 Posts1,056,368 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | I tried to look it up first but couldn't find anything, in changing from a 216 to a full pressure 235, do I change the oil gauge or what cause it only reads to 30? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | No need to change the gauge unless you want to . The earlier vs later models had difference calibration.
My 37 only registers 30 lbs....but I had it calibrated by D&M Restorations so that the actual pressure is "twice" what it reads, but the V8 still keeps it pegged but it hasn't hurt anything in 18 years. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I put a 235 in my 41 during total restoration. I had my gauge panel rebuilt with a gmc gauge. 0 to 60 and it works fine. You could put a new gauge in it or just watch it read 30 and know it is enough. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | You could also find an original 1941-46 oil pressure gauge for a GMC. The GMC gauge is 0-80 PSI as engines were already insert bearings at that time. Swapping the face plate and painting the needle to the Chevrolet color scheme will make your alteration nearly invisible. You will have to remember the true PSI as the original dash cluster glass will still read the low oil pressure markings of a splash oiler (ie, half way on the gauge will now mean 40 PSI vs the 15 PSI indicated on the glass).. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | What was done with my son's 46 2 ton. Original 235 was replaced with a 54 235 from a 1 ton truck.
I bought a NOS GMC gauge. The color is so slightly off and the gauges so dimly lit that the color difference is not easily noticed.
Now the problem with the swap.
The gauge numbers are printed onto the instrument cluster glass. So changing the gauge does not change the numbers.
You can buy a new GMC instrument panel glass that is a direct bolt in for the Chevy glass.
So what is the problem?
The GMC glass will give you the correct oil pressure readings. Though the GMC speedometer numbers are different then the Chevy's so your speed will be off.
Buy a GMC speedometer or correct the oil pressure readings in my head.
Correcting the oil pressure reading in my head seems easier then getting a GMC speedometer because once that speedometer gets change who knows what other problems will be added.
If I knew about be able to get the original oil pressure gauge re-calculated I would of maybe went that way.
If I knew that no harm would of been done with the original gauge being pegged maybe I would of went that way.
What I do definitely know is that I would of stayed with having the original 46 engine being rebuilt due to all the little changes that have popped up putting in the later "direct bolt in" 54 engine. Jeffrey
| | | | | Joined: Jun 2015 Posts: 201 Shop Shark | | Shop Shark Joined: Jun 2015 Posts: 201 | Thanks for the help, I'll probably just leave the gauge that's in it for now, worry about it when the job is done | | |
