3 members (Otto Skorzeny, WICruiser, TUTS 59), 96 guests, and 2 robots.
Topics128,093
Posts1,056,478
Members48,444
#1239246 10/14/2017 7:12 PM
I
I Offline
I've been looking for a 235 since I lost a piston and killed my 216.
Ran across a 1961 blue flame 140 that's out of a Biscayne, has 1300 miles on it since a complete rebuild, would that be a good motor for my 41?
Stovebolter -- the Next Generation
(I'm 20)
1941 Chevy 1/2-ton pickup
"Lucy"
More pix on Photobucket
1967 Ford Mustang - "Sally"
What's the price? That would be a very good swap, with only a few minor modifications to make such as relocating the water pump with Pre-68 Dave's adapter plate. The pump on that engine is about 3" lower on the block and it gets the fan way off center on the radiator. You'll also need to use the bellhousing, clutch, flywheel, and starter from the trashed 216 to complete the transplant.
That is a good choice, but there a few things that would need work to put it in.
1. water pump conversion.
2. 1960 and later dropped the pivot point for the stock throttle linkage.(I have one remedy on my blog).
3. drilling timing plate for your front mount.
4. Manifold. 41 has straight down exhaust dump, 62 will angle back. So head pipe work would need to be done. Or, I personally use adapter rings in the head to allow the use of the 216 manifold on the 235.
My Blog
I
I Offline
There asking 1000 but I asked if they would come down waiting on a reply, as far as the modifications that doesn't sound to bad
(I'm 20)
"Lucy"
I
I Offline
He won't come off 1000 and is hopeing it'll be bidded up as it's on eBay, I think that's gonna be to expensive for me
(I'm 20)
"Lucy"
Does he have a reserve? Is he close by? If so and it's to your liking, tell him you'll pay the reserve and pick it up.
Rick
1939 Chevrolet Stake Truck
I
I Offline
No I don't think he has a reserve but I can't afford 1000 right now
(I'm 20)
"Lucy"
Id only pay that price if the seller can document with receipts what was done and by whom. Best of luck
1946 1/2-Ton Chevy
I wonder why a 1300 mile "rebuilt" engine is for sale. Did he wreck the car, install a V8, or what? Ask for invoices proving the rebuild, and keep negotiating!
No 216/235/261 is worth more than $400 to me if I don't know the guy, and I know the guy would give me my money back if it needs significant work.
I am particularly skeptical about a $1,000 price. It costs 3 times that much to have one rebuilt.
Keep looking.
A friend of mine has a 210 blue flame in a 55 sedan he never new the term stovebolt and I don't know about blue flame could someone enlighten me
Here is some information on a Stove Bolt Six engine.
The name was used for all 6 cylinder Chevrolet engines from 1937-1963 (194, 207, 181, 216, 235 (two types), and 261)
The Chevrolet Blue Flame Six was the name for the high-pressure Chevrolet 235 6-cylinder engine that first appeared in 1953.
A significantly modified version of that Blue Flame Six was used in 1953/1954 and some 1955 Corvettes.
Hi-Compression 160hp 235 with 3-side-draft carburetors (and a modified lift cam in 1954).
http://www.superchevy.com/features/...blue-flame-six-first-engine-illustrated/
The name was used from 53-62 and most commonly referred to the car version of the 235 because it was painted blue. Not that it matters, but maybe someone has a reference to a Blue Flame truck engine (a few of us sickos would like to see it).
Last edited by tclederman; 10/16/2017 12:44 PM. Reason: added Stove Bolt information
If it's on Ebay it must be invisible- - - - -nothing I can find there even remotely resembles the one you're describing. I'm beginning to smell the odor that's found downwind from a feed lot with a bunch of beef cattle!
I
I Offline
Here's the link
http://www.ebay.com/itm/1961-COMPLETE-CHEVROLET-235-6-CYLINDER-ENGINE-W-3-SPD-TRANSMISSION-READY-TO-GO/132361770038?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140131123831%26meid%3Dc90ea99b633f4576a63b47b5ceedc15c%26pid%3D100170%26rk%3D3%26rkt%3D3%26sd%3D122743855399&_trksid=p5411.c100170.m2943
(I'm 20)
"Lucy"
Wellll- - - - -it looks good, and he's offering the transmission along with it. You might find a buyer for the trans to offset some of the cost. Since the car is supposedly being butchered, at least there's a reason for a good condition engine being offered at a discounted price. Ditto on the cost estimate for a good rebuild- - - -$2500.00 minimum, at least in my neighborhood, and more if much machine work is involved!
Thanks just read all about blue flame
' Offline
PIC of a Chevy Blue Flame 140 6 cyl. engine .
'54 3600
George
1954 3600
Now cruising in
The Passing Lane
I
I Offline
Ok the blue flame has a wierd water pump on it, not like a stovebolt Normal water pump,
How would I go about getting it to clear the radiator?
(I'm 20)
"Lucy"
The water pump on the 235 engine is a bit longer and mounts lower than the water pump on a 216 engine. This can cause a problem with radiator clearance as well as the fan cooling only the lower half of the radiator. There are several solutions to this problem but the easiest is to purchase a 216 style water pump and adaptor plate which permits it to be mounted in the same position as the earlier engine.
Other solutions involve shortening the 235 water pump shaft, changing pulleys and fans, and moving the radiator forward a bit.
