| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 75 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 75 | I have a '53 3100 pickup in the works (about 60-70% complete) and recently opened the transmission intending to put in gaskets and front/rear seals. This is the stock 3 speed trans hooked to a torque tube. Inside I found grindings, worn gears and some very bad attempts to repair damage to almost all shafts and gears. None of this was visible from the outside. I have completed a swap from the 216 to a 235 using the 216 bell housing so the rear motor mounts could remain the same. Since funds are in short supply, I was intending to leave the drive train stock until future funds (hopefully) would allow upgrading to another transmission and open drive shaft. Now the bad trans requires a change in plans. Now the questions along with some info: a fellow bolter has offered a Muncie SM-318 3 speed which he believes will bolt up to the 216 bell housing on the 235 engine. He has a drive shaft which could be altered to fit also. Can you advise if the Muncie will indeed bolt up to my engine? Can you advise the best approach to change the rear end to accommodate the open drive line and suggest a good replacement? The Muncie trans and drive shaft came from a '59 Chevy truck per the owner/bolter. I need to leave the replacement rear end in the original position so the wheel/tire position in the rear fenders will remain the same. One good point to consider: This may solve the old gear ratio problem and eliminate the need to replace the ring gear and pinion in the old rear end....Oh Well ! Thanks for any advise, warnings, encouragement and/or information.
'53 3100 Short Bed Texas Peace Officer - supporter of the Badge and the Blue Line Pain is part of life, Misery is an option.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | The pumpkin out of the '59 will work in your current housing. Just take out the torque tube and put in the '59. If your lucky it may be a 3.38 or maybe its a 3.42, that was in that year along with a 3.90
there are several years of pumpkins that will work replacing the torque tube. I think all the way up to 62 or maybe later. I'm sure others who have done this will chime in with more info..... | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1955-62 1/2 ton pumpkin will bolt in the 53 axle housing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Can you still use the stock axles of the 53 with the 55-62 pumpkin? Will you have pinion angle problems with this setup? 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Axle splines are the same. You will need to add modern style spring pads with this set-up, although there is more to that. I could talk you through that if needed.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The later trans will bolt up but you will likely have to use the side cover from your original trans to match your linkage. This will require using the 1-R shift fork from the later trans providing it has the same internal configuration. Modifying a driveshaft is by no means cheap, and you have to find another rear end. I would suggest putting an ad in the swap meet and finding a good original transmission. There are many people taking them out to modify their AD trucks to updated engine/transmission/differential conversions. I see them advertised all the time. I purchased one a couple of years ago for a 54 I was working on. It doesn't solve your low gear ratio issue but it would put the truck on the road. Fred
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I'm with Fred on this one. If your ultimate goal is to upgrade the drive train in the future when you get the funds, look for a stock torque tube 3 speed from a '48-'54 truck. You could probably find a usable one from a truck with trees growing through the frame in a hedgerow as long as it isn't sitting in water and still has gear lube in it.
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Drop me a PM- - - - -I might have the trans you're looking for. Jerry
| | | | | Joined: Feb 2014 Posts: 75 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 75 | Thanks Fred, 52 Carl and Jerry PM sent
