2 members (Peggy M, Ponchogl),
52
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 2 Junior Member | | Junior Member Joined: Dec 2006 Posts: 2 | I need help, I have a 1961 chevy 1/2 ton short box 4x4. I bought it from the second owner, the first owner was his father in law. The truck is all origanal except paint. It is now orange in color and appears to have been painted this color more then once. I do see in spots like the firewall where paint has peeled and reveals a possible light green color. I would like to know the origanal color, but i can't find a color to match the paint code from the data plate. My paint code is RPO-710A, that is exactly how it appears on the plate. Thanks for the help | | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | The chips from these sites make the color look much bluer than it is.
The chips I have are the ones offered by the site tclederman mentioned and he is absolutley correct when he mentions distortion,fading,PC's color.
The color 710A is Tampico Turquoise Metallic and is beautiful as were most colors for 61.
I saw a book recently at our local Barnes and Noble that had a listing of GM's paint codes with color chips so you can go to your local book store and have a look.Also a lot of the paint and body supply stores have old chip books and will help look up colors for you.
Hope this helps,Hobert
"The Lord is my shepherd"
| | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | I also have several paint books, Dupont, Ditzler(PPG), R-M, and maybe a few that no longer are around...BB | | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | I am not looking for chips but actual touch up paint. I am touching up a 1911 Stanley Steamer with Brewster green as the main body color. I was hoping to find a small touch up bottle of paint. Has anyone seen these for the older colors? Joe | | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | Here is Du ponts paint chip page. You have do a little hunting but it has some cool colors.
[url=http://www.performancecoatings.dupont.com/bowstreet5/webengine/dpc/common/Controller/Action!_pageDispatcher/InnerModel!dpc/modules/Login/OuterModel!dpc/common/Controller/InnerAction!visitorAction[url]]http://www.performancecoatings.dupont.com/bowstreet5/webengine/dpc/common/Controller/Action!_pageDispatcher/InnerModel!dpc/modules/Login/OuterModel!dpc/common/Controller/InnerActio n!visitorAction[url] | | | | | Joined: Mar 2005 Posts: 37 Junior Member | | Junior Member Joined: Mar 2005 Posts: 37 | Joe H, Take your Stanley Steamer or a piece of it that is the color you need to a Automotive paint supplier. The most of them now days are equipted with a gun that they pass over the piece and it feeds info into a computer that tells the Saleperson what colors to mix for your need. I have been doing color matching for over 30 years and these things are Quick and very very accurate. They are great for faded out colors or ones that for some unkown reason did not come out the right color.
BAN LOW PERFORMANCE DRIVERS... NOT HIGH PERFORMANCE CARS !!
