7 members (WICruiser, Peggy M, 55shaker, Hotrod Lincoln, Steelonsteel, TS3600, GRNHydra), 124 guests, and 3 robots.
Topics128,141
Posts1,056,470
Members48,441
#1215417 04/30/2017 11:53 PM
While waiting on the machine shop, I am cleaning/repairing odds and ends. I was working on the distributor the other day, and got to wondering about the grease cup on the side. Looking at it, I don't see how the spring is supposed to help with greasing the shaft. The whole thing looks pretty strange. I would guess that the idea is to fill the cap with grease, then tighten it every so often to force grease into the distributor shaft. Has anyone else worked on these? I'm thinking about just leaving the spring out.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
H Online: Content
Wrong move! The spring bears against a plastic (actually Bakelite) insert that puts pressure on the distributor shaft to dampen out any wobble created by worn distributor housing bushings. There is enough clearance around the insert to allow grease to get past it and keep the shaft lubed. If you leave the spring and shaft stabilizer out there will be variations in point dwell and erratic ignition timing.
Thanks for the information. At least I now know the reason it's there. Now I just have to find the little plastic insert, which doesn't seem to have been inside mine.
Tim
Tim
H Online: Content
If the spring rubs the shaft, it will wear a groove in it. Clean the crud out of the hole with carburetor cleaner and shine a light in there. If you can see the shaft turning, the plastic piece is missing. Sometimes it's very hard to see unless you do a complete teardown, including removing the drive gear and taking the shaft out of the housing.
I'll have to dig to get it but someone here listed the number for a plastic piece that works very well. I think it was available at Lowes.
Nylon flat washer, Hillman #884566
Ed
My Blog
Thanks everyone. I'll go out and pick up that nylon washer tomorrow. One more detail dealt with, 159,622 left to go!
Tim
Tim
Former BMW Rider
Former BMW Rider
Given the discussion in this thread, I took the grease cup cap off my 1955 Chevy 235 distributor and found the spring inside the grease cup. Next, I removed the remainder of the grease cup from the base of the distributor in search of a fiber plug or flat washer. I thoroughly cleaned everything and didn't find either one in the threaded bore at the base of the distributor.
It looks like I need the flat washer too; however, what holds the cap on the grease cup, just friction? The manual confirms the order of installation, assuming I have the original distributor.
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Originally the fitting that screws into the distributor has a piece of leather crimped around it to prevent the grease to leak out, and I suppose to help keep it from backing off.
My Blog
Former BMW Rider
Former BMW Rider
Thanks Dave!
The leather on mine is obviously worn resulting in a loose fitting cap. Can the leather be replaced or is it easier to find a different grease cup assembly?
It looks like an o-ring could ride on the leather providing a positive seal.
Andy
' Offline
The grease cup requires re-greasing every 5,000 miles
with Delco Remy # 2 & 1/2 grease.
photo@photobucket
http://i669.photobucket.com/albums/.../805579_Dist_CUP_GM_NOS__zpsnazwrui3.jpg
Llewellyn Obsolete
North Ridge, CA.
phone: 818-363-5094
Llewellyn has ( 1 ) GM # 805579 in stock.
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
H Online: Content
Tap the grease cup gently with a hammer to make it slightly out of round, and the thread will hold itself in place from friction.
' Offline
GM # 2.364 - GM # 805579 Grease Cup
Superseded to: GM # 1955293 in June ( 1966 )
GM # 1955293 utilizes the same 1/8 " pipe thread as GM # 805579
photo@photobucket
http://i669.photobucket.com/albums/...OS_Old_GM_number_805579__zps8w17oj1l.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
On mine the cover screws onto the body with a very fine thread. Being (I think) aluminum it would be awfully easy to destroy those threads. I am going to use teflon tape on the threads to seal it, no sign of the leather.
Tim
Tim
' Offline
Distributor Grease Cup - GM # 2.364 - GM # 805579
with Spring & Plug
photo@photobucket
http://i669.photobucket.com/albums/..._Grease_Cup_Spring_Plug__zpszhlvfert.jpg
When is the last time you greased the distributor
Shaft ?
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
The last time the distributor shaft was greased is anyone's guess. I purchased the engine non-running, and am in the process of rebuilding. While I'm waiting for the machine shop to finish I am going through all of the parts and pieces cleaning, oiling, greasing, and painting. I went out yesterday and bought a nylon disc and installed it today. Went in easy, fit fine, so I guess that is fixed up now.
Tim
Tim
Maybe this has been asked or discussed before but I haven't found an answer to it yet. I was doing some work on my distributor today and I am wondering if there is any reason I cannot replace my grease cap with a grease zerk? My cap is not in the best shape and I cant think of a reason a grease zerk wouldn't work instead of tracking down the specific cap for it. I am assuming you give the cap a turn every so many miles to push a little grease into the shaft and then refill it every 5000 miles. I could just break out the grease gun every so many miles and give it half a shot. Or is there something I am not considering here?
H Online: Content
As long as the spring and disc are tensioned by the grease fitting that should work. The grease cap was a simple, easy way to keep the distributor shaft lubed without having to hunt up a grease gun and hope it had the right kind of grease in it. A capful was at least a year's supply, and when points were usually changed every six months of daily driving, a competent mechanic never let the cup get empty.
What kind of grease does it take anyway? Would the same stuff I use in the king pins and spring shackles not work?
Yes
I have a 1# can of VITA POWER CUP GREASE, Part # 2T3501
The label reads: Calcium base lubrication grease.
Designed for cups...distributors, farm equipment, electric motor shafts, etc.
Unfortunately you will need a Way Back Machine (and Mr Whoopee to operate it) to go back in time to buy it from Western Auto.
This grease is quite different than axle grease. It looks like butterscotch.
