2 members (1955 1 Series, Sjm),
152
Mod | | | Forums66 Topics128,278 Posts1,058,457 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | While waiting on the machine shop, I am cleaning/repairing odds and ends. I was working on the distributor the other day, and got to wondering about the grease cup on the side. Looking at it, I don't see how the spring is supposed to help with greasing the shaft. The whole thing looks pretty strange. I would guess that the idea is to fill the cap with grease, then tighten it every so often to force grease into the distributor shaft. Has anyone else worked on these? I'm thinking about just leaving the spring out. Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road. Tim
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Wrong move! The spring bears against a plastic (actually Bakelite) insert that puts pressure on the distributor shaft to dampen out any wobble created by worn distributor housing bushings. There is enough clearance around the insert to allow grease to get past it and keep the shaft lubed. If you leave the spring and shaft stabilizer out there will be variations in point dwell and erratic ignition timing. Jerry
| | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | Thanks for the information. At least I now know the reason it's there. Now I just have to find the little plastic insert, which doesn't seem to have been inside mine. Tim
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | If the spring rubs the shaft, it will wear a groove in it. Clean the crud out of the hole with carburetor cleaner and shine a light in there. If you can see the shaft turning, the plastic piece is missing. Sometimes it's very hard to see unless you do a complete teardown, including removing the drive gear and taking the shaft out of the housing. Jerry
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | I'll have to dig to get it but someone here listed the number for a plastic piece that works very well. I think it was available at Lowes. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Nylon flat washer, Hillman #884566
Ed
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | Thanks everyone. I'll go out and pick up that nylon washer tomorrow. One more detail dealt with, 159,622 left to go! Tim
| | | | | Joined: Dec 2013 Posts: 795 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 795 | Given the discussion in this thread, I took the grease cup cap off my 1955 Chevy 235 distributor and found the spring inside the grease cup. Next, I removed the remainder of the grease cup from the base of the distributor in search of a fiber plug or flat washer. I thoroughly cleaned everything and didn't find either one in the threaded bore at the base of the distributor. It looks like I need the flat washer too; however, what holds the cap on the grease cup, just friction? The manual confirms the order of installation, assuming I have the original distributor. Thanks, | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Originally the fitting that screws into the distributor has a piece of leather crimped around it to prevent the grease to leak out, and I suppose to help keep it from backing off.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2013 Posts: 795 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 795 | Thanks Dave!
The leather on mine is obviously worn resulting in a loose fitting cap. Can the leather be replaced or is it easier to find a different grease cup assembly?
It looks like an o-ring could ride on the leather providing a positive seal. | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | The grease cup requires re-greasing every 5,000 miles with Delco Remy # 2 & 1/2 grease. photo@photobucket http://i669.photobucket.com/albums/.../805579_Dist_CUP_GM_NOS__zpsnazwrui3.jpgLlewellyn Obsolete North Ridge, CA. phone: 818-363-5094 Llewellyn has ( 1 ) GM # 805579 in stock. George '54 3600
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Tap the grease cup gently with a hammer to make it slightly out of round, and the thread will hold itself in place from friction. Jerry
| | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | On mine the cover screws onto the body with a very fine thread. Being (I think) aluminum it would be awfully easy to destroy those threads. I am going to use teflon tape on the threads to seal it, no sign of the leather. Tim
| | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | The last time the distributor shaft was greased is anyone's guess. I purchased the engine non-running, and am in the process of rebuilding. While I'm waiting for the machine shop to finish I am going through all of the parts and pieces cleaning, oiling, greasing, and painting. I went out yesterday and bought a nylon disc and installed it today. Went in easy, fit fine, so I guess that is fixed up now. Tim
| | | | | Joined: Mar 2017 Posts: 88 Shop Shark | | Shop Shark Joined: Mar 2017 Posts: 88 | Maybe this has been asked or discussed before but I haven't found an answer to it yet. I was doing some work on my distributor today and I am wondering if there is any reason I cannot replace my grease cap with a grease zerk? My cap is not in the best shape and I cant think of a reason a grease zerk wouldn't work instead of tracking down the specific cap for it. I am assuming you give the cap a turn every so many miles to push a little grease into the shaft and then refill it every 5000 miles. I could just break out the grease gun every so many miles and give it half a shot. Or is there something I am not considering here?
Thanks | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | As long as the spring and disc are tensioned by the grease fitting that should work. The grease cap was a simple, easy way to keep the distributor shaft lubed without having to hunt up a grease gun and hope it had the right kind of grease in it. A capful was at least a year's supply, and when points were usually changed every six months of daily driving, a competent mechanic never let the cup get empty. Jerry
| | | | | Joined: Mar 2017 Posts: 88 Shop Shark | | Shop Shark Joined: Mar 2017 Posts: 88 | What kind of grease does it take anyway? Would the same stuff I use in the king pins and spring shackles not work? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | I have a 1# can of VITA POWER CUP GREASE, Part # 2T3501 The label reads: Calcium base lubrication grease. Designed for cups...distributors, farm equipment, electric motor shafts, etc. Unfortunately you will need a Way Back Machine (and Mr Whoopee to operate it) to go back in time to buy it from Western Auto. This grease is quite different than axle grease. It looks like butterscotch.
