5 members (Bill Hanlon, LAROKE, rfs56trk, Maybellene, klhansen), 140 guests, and 1 robot.
Topics128,034
Posts1,055,544
Members48,425
#1236419 09/26/2017 12:35 AM
1 Offline
Hello all, I installed a 261 in my '52 Burb. I've got it all plumbed in and tried starting it today. Long story short, I've tried 2 different fuel pumps including a new one from Napa. I finally got it running and took a short drive around the block. The motor sounded like it was loading up so I gave it some gas and it died. The only way I can get it running is to pour some gas in the carburetor.
When I installed the pump to get the fuel pumping, I had to eliminate the gasket to the stroke long enough to pump fuel. It doesn't feel like the cam lobe is worn down.
Could I have the wrong pumps?
Does anyone have a definitive part number?
Very frustrated....
1954 Chevy 3100
1952 Chevy Suburban
What year 261?
In 1954 the same fuel pump was used on 235 & 261.
In 1958 the same fuel pump was used on 235 & 261, but it was different from 1954.
What pump did you get from NAPA?
Sir Searchalot
Sir Searchalot
A 1/16 thick smashed down gasket makes a difference? Don't think so. As Tim is trying to do for you, search Rockauto for your year motor. They have the definitive part number(s). What did you ask for at the pump store? Did the new pumps match the old one?
I hope you have the wrong pump so we don't have to go thru all this again. (not your fault). If you have the right pump, please search on here to read all the many posts on this subject. Pumps, carbs, filters, dirty gas, floating particles, gas cap vent, vacuum leak.............bad coil, bad condenser., loose wires, ignition switch intermittency.
bartamos has me figured out
(1958 is shown - check other years, the fuel pumps differ)
Sir Searchalot
Sir Searchalot
Yeah, but I didn't know you already figured it was a 58 Canadian. Too good, too fast.... Sherlock Holmes.
Good work Dr. Watson.
1 Offline
Thanks, I'll double check the Napa pump I purchased for a part number. My motor is a 1958 Canadian built Pontiac motor, if that matters.
1954 Chevy 3100
1952 Chevy Suburban
1 Offline
Napa part # B-0145-P
1954 Chevy 3100
1952 Chevy Suburban
Sir Searchalot
Sir Searchalot
Looks like B0147P is correct and your number is wrong. As Tim said, same pump as a 235.
However, tonight the NAPA site changes it's mind every time I search 0145 and 0147. Sometimes says no for both, sometimes yes, sometime either/or. Soooooooooooo I am going by the fact that the Rockauto says 0147.
The Airtex 40217 checks out also.
1 Offline
Thank you I'll order one
1954 Chevy 3100
1952 Chevy Suburban
Sir Searchalot
Sir Searchalot
Don't know if you read the whole edited post.
1 Offline
I'm going to order The Airtex 40217
1954 Chevy 3100
1952 Chevy Suburban
Sir Searchalot
Sir Searchalot
$39 at Amazon. Also Carter M2999 is equivalent.
