0 members (),
67
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 49 | I have inherited a 6 cyl chevy engine want to know the year etc. I think it is a 235. The number stamped in block behind the Dist. is FI1090R.It has a screw on oil filter at the front on the dist side.So it is newer than the '54 I have. Thanks for the help John B. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Post the block/head casting codes and date codes.That will confirm date. No 235 had a screw-on oil filter (from the factory/dealer). No 235 normally had a GM factory/dealer oil filter on the distributor side. Can you post a photo of the oil filter? Can you post a photo of that "Engine Serial Number"? | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | The letter "R" is a big truck. Decode your serial #The block casting # will help identify the engine size, and the block casting date code will confirm the year. Maybe you got lucky and inherited a 261.
-Tom
1950 Chevy 3100 w/ 1956 235
