Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#123600 12/16/2006 5:18 PM
I'm in the process of cleaning the frame to get it ready to paint and wondering what everybody else does with all the extra stuff Rivited on to the frame (Like running board mounts and spring mounts). Do you leave it on and clean and paint it or do you drill out the rivits and bolt it on later?
thanks,
#123601 12/17/2006 8:31 PM
If you plan to keep the factory mounting brackets for reattaching accessories, leave them on the frame with the factory rivets intact. If you do not plan on reusing them, grind or cut off the rivet heads and remove them. If you decide to remove items that are going to be reinstalled after the frame is painted, I suggest reattaching with grade 8 hardware, to be on the safe side. Good luck with your project and Happy Holidays.
Tony
#123602 12/18/2006 8:26 AM
I am glad I decided to pull all the brackets on my frame to paint, because they were loaded with rust behind them and alot of the rivets were worked loose. Just something to think about on a 50+ year old frame.
#123603 12/18/2006 4:39 PM
Anonymous
Unregistered
Anonymous
Unregistered
No real need to remove them. Leave them in place.
#123604 12/22/2006 1:07 AM
leave em on.. thats that I did and it turned out very nice!
1952 Chevy 5 Window Restoration
#123605 12/23/2006 12:20 AM
I left mine on also, except where we made alterations.
