| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 45 New Guy | | New Guy Joined: Dec 2005 Posts: 45 | I'm in the process of cleaning the frame to get it ready to paint and wondering what everybody else does with all the extra stuff Rivited on to the frame (Like running board mounts and spring mounts). Do you leave it on and clean and paint it or do you drill out the rivits and bolt it on later?
thanks, | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | If you plan to keep the factory mounting brackets for reattaching accessories, leave them on the frame with the factory rivets intact. If you do not plan on reusing them, grind or cut off the rivet heads and remove them. If you decide to remove items that are going to be reinstalled after the frame is painted, I suggest reattaching with grade 8 hardware, to be on the safe side. Good luck with your project and Happy Holidays.
Tony | | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | I am glad I decided to pull all the brackets on my frame to paint, because they were loaded with rust behind them and alot of the rivets were worked loose. Just something to think about on a 50+ year old frame. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | No real need to remove them. Leave them in place. | | | | | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | leave em on.. thats that I did and it turned out very nice!
1952 Chevy 5 Window Restoration
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I left mine on also, except where we made alterations. | | |
