6 members (1955 1 Series, Spikeytop, Wayne67vert, Otto Skorzeny, Bill Hanlon, carbking), 94 guests, and 7 robots.
Topics128,181
Posts1,057,189
Members48,465
I swapped out the 4.11 rear end in my '53 3100 with a 3.55 gear set. I have a 1960 261 in it and 27" inch high tires. What should I expect in terms of RPMs at 60 or 65 mph? Thanks!
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
Use this. I will let you figure, no trans listed, auto or stick.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Thanks, I did use that but my results are quite different. For example, that calculator indicates that I should be running 2830 at 65 mph but my tach only reads 2150. I have a 3 speed on the column. What are others seeing at that speed?
~Denny
1953 Chevy 3100
What type/size tires?
What measured-diameter of your tires? (not the "rated" advertized tire-diameter)
12v 6-cylinder tachometer?
3.55 rear end
1:1 high gear
27" diameter tires
65 mph
2872 at 65 mph
2651 at 60 mph
http://www.csgnetwork.com/multirpmcalc.html
I have radial trucks tires that the manufacturer shows 30" rolling diameter, but on my 6.50x16" wheels the rolling diameter is about 31.5".
Well, DUH! I had the tach set on 8 cylinders. When I corrected it to 6 cylinders my numbers matched up well. Sorry for this distraction, guys.
~Denny
1953 Chevy 3100
No distraction. This post might help someone else in the future.
