| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 18 Junior Member | | Junior Member Joined: Nov 2006 Posts: 18 | Willa 48-52 chevy grill fit on the frontend of a 52 gmc? This may sound dumb, but I have a gmc cab, but like the chevy front ends a little better. | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | if i remember correctly you would have to use chevy hood fenders and grill support becuase they were different but chevy front on a gmc cab should fit fine | | | | | Joined: Jan 2005 Posts: 135 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 135 | Also splash pan is differeent, fenders are ok for both Gmc and Chevy. | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | You can make anything work with enough metal work, but if it were me, Id leave in the GMC grill. The front ends are different and you might be opening a can of worms. Cecil......... | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The front of the frame is slightly longer to fit in the long GMC motor, but the sheet metal will all bolt up to the cab ok. The only common sheet metal between GMC's and Chevies is the cab, doors, and bed. Fenders, grille, hood, tailgate are all differant. You will have to mess with the radiator mounts to get it all to fit.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2004 Posts: 2,400 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,400 | I wouldn't discard your GMC parts. It sounds like a lot of guys have the same idea and they may be getting hard to find. There are a lot of die hard GMC guys out there, and the GMC parts (in good shape) may be worth hanging on to for awhile.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I agree- GMC trucks are a lot less common. I'm sure you can find somebody to trade parts, if not trucks. Please don't scrap them.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2006 Posts: 18 Junior Member | | Junior Member Joined: Nov 2006 Posts: 18 | I would'nt scrap them, in fact the more I think about it, you don't see a lot of gmc trucks. I think I'll keep my GMC a GMC, hell it's still a GM! | | | | | Joined: Nov 2006 Posts: 18 Junior Member | | Junior Member Joined: Nov 2006 Posts: 18 | Oh, and thatnk you guys for all your help and opinions! | | | | | Joined: Jan 2007 Posts: 1 New Guy | | New Guy Joined: Jan 2007 Posts: 1 | 53 gmc with camaro clip i was going to do the same thing not sure now mabey i will just move grill out an inch to change the look a bit . it was born a gmc and you dont see many | | |
