8 members (J Lucas, klhansen, Tronman, electors, 78buckshot, cmayna, JW51, 1 invisible), 73 guests, and 4 robots.
Topics128,042
Posts1,055,497
Members48,424
#123437 12/09/2006 4:30 AM
Junior Member
Junior Member
Willa 48-52 chevy grill fit on the frontend of a 52 gmc? This may sound dumb, but I have a gmc cab, but like the chevy front ends a little better.
#123438 12/09/2006 7:28 AM
if i remember correctly you would have to use chevy hood fenders and grill support becuase they were different but chevy front on a gmc cab should fit fine
1955 Chevrolet 3100 2nd
1954 International Harvester R-110
My Webshots Pictures
#123439 12/09/2006 10:45 PM
Also splash pan is differeent, fenders are ok for both Gmc and Chevy.
#123440 12/10/2006 8:05 AM
You can make anything work with enough metal work, but if it were me, Id leave in the GMC grill. The front ends are different and you might be opening a can of worms. Cecil.........
#123441 12/11/2006 5:02 AM
The front of the frame is slightly longer to fit in the long GMC motor, but the sheet metal will all bolt up to the cab ok. The only common sheet metal between GMC's and Chevies is the cab, doors, and bed. Fenders, grille, hood, tailgate are all differant. You will have to mess with the radiator mounts to get it all to fit.
Paint & Body Shop moderator
#123442 12/11/2006 6:25 AM
Former Workshop Owner
J Online: Content
I wouldn't discard your GMC parts. It sounds like a lot of guys have the same idea and they may be getting hard to find.
There are a lot of die hard GMC guys out there, and the GMC parts (in good shape) may be worth hanging on to for awhile.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#123443 12/11/2006 7:57 PM
I agree- GMC trucks are a lot less common. I'm sure you can find somebody to trade parts, if not trucks. Please don't scrap them.
#123444 12/12/2006 1:10 AM
Junior Member
Junior Member
I would'nt scrap them, in fact the more I think about it, you don't see a lot of gmc trucks. I think I'll keep my GMC a GMC, hell it's still a GM!
#123445 12/12/2006 1:11 AM
Junior Member
Junior Member
Oh, and thatnk you guys for all your help and opinions!
#123446 01/16/2007 2:10 AM
53 gmc with camaro clip i was going to do the same thing not sure now mabey i will just move grill out an inch to change the look a bit . it was born a gmc and you dont see many
