4 members (Nick in Manitou, Bill Hanlon, moparguy, Peggy M), 135 guests, and 0 robots.
Topics128,109
Posts1,056,269
Members48,439
#1233396 09/04/2017 9:59 PM
I have a 1949 GMC 1 ton dually. What motor does it have if it's original?
I just finished a 1946 chevy pickup street rod
now on a 1950 chevy 3100
also a GMC 220 with duals
and a 1948 chevy 2 ton
Leo Offline
Moderator
Moderator
Here in Canada, I believe it would be a 216.
So, I found out that GMC used a separate motor in the A.D. TRUCKS. Trucks either had a 228 or a 248 , both being full oil pressure with insert bearings
So, now my question is ,, did all the engines use the same block or was the GMC block bigger ? Are these GMC engines hard to get parts for ?
Thanks, Charles Pretzer
The "previous" what?
A USA GMC light truck would have had a 228 (1/2 ton to 1-ton, 250 series or smaller).
Offline
Offline
Just behind the distributor, you'll find a number stamped on the machined surface block. The first 3 digits will be the engine size. Could be a 248 or 270. I don't recall what year they began to produce the 302
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
"Could be a 248 or 270."
Probably not?
Post the engine serial number code as suggested above by Elderly Iron.
Do not be surprised if there is a letter before the engine displacement.
Offline
Offline
55-9 I'm sure on. 48-54, not so much, though the 50 GMC 2.5 ton did have a 248 in it with the big port head. Not that it could be said it was original! www.oldgmctrucks.com is the best place to find ID info. Hard to navigate, but a wealth of info.
Elderly Iron
Serial number on motor B228 239989
Serial number on cab door B228323898
Are they suppose to be the same number?
No, they are not supposed to be the same.
The code on the door plate should contain model information.
Rob English's website has this useful information.
Here is other engine serial number information from Rob's website.
Some states used engine serial number for vehicle title. Perhaps that's what happened here, and then someone made up a replacement door tag with number from title instead of the correct/original door tag.
•1952 Chevrolet 3800 pickup
---All pictures---
In NC and NY, there is a good chance you might need a bonded title (because those codes should not be the same).
Is that code on your title/registration? If it us, and it is titled/registered in your name, you are OK.
thanks everyone for the input !! very much appreciated
Crusing in the Passing Lane
So you have a GMC 228 cu. in. engine that has probably been rebuilt once.
Ed
Moderated by  Dusty53
