Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Simon1954, KingG), 56 guests, and 4 robots.
Topics128,009
Posts1,055,297
Members48,419
#1232021 08/25/2017 10:42 PM
Done it before but years ago and I am old now so I have forgotten how to remove the stomp button from shaft to the starter linkage. I recall the button has a threaded nut attached to it or so I thought. If it does how do I keep the shaft from turning? Or is there a fixed nut on the shaft?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
The shaft has a nut at the bottom end of it which acts as a lock nut to secure it to the linkage which is outside of the cab. The button itself has no lock nut. That end (the top end) is 1/8" NPT which is a tapered thread, which is inherently self-locking. There is a flattened spot on the shaft near the button which you can get a small wrench on to hold it while you unscrew the button. The underside of the button is hex-headed.
Now I must go outside now and enjoy the recent explosion of wild rabbits in my suburban neighborhood, which is a good sign that the coyotes have not moved in................yet.
Carl
Thanks Carl. Now I recall as I had changed the rubber boot many years ago. I need a new one now but will at least paint the button now. Along with being old I am also lazy with no ambition or initiative since losing my wife.
You take care of those rabbits - hear!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Hey! That truck ain't gonna fix itself, Hoss.
