| | | Forums66 Topics128,006 Posts1,055,267 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Done it before but years ago and I am old now so I have forgotten how to remove the stomp button from shaft to the starter linkage. I recall the button has a threaded nut attached to it or so I thought. If it does how do I keep the shaft from turning? Or is there a fixed nut on the shaft? | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | The shaft has a nut at the bottom end of it which acts as a lock nut to secure it to the linkage which is outside of the cab. The button itself has no lock nut. That end (the top end) is 1/8" NPT which is a tapered thread, which is inherently self-locking. There is a flattened spot on the shaft near the button which you can get a small wrench on to hold it while you unscrew the button. The underside of the button is hex-headed. Now I must go outside now and enjoy the recent explosion of wild rabbits in my suburban neighborhood, which is a good sign that the coyotes have not moved in................yet. Carl
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Thanks Carl. Now I recall as I had changed the rubber boot many years ago. I need a new one now but will at least paint the button now. Along with being old I am also lazy with no ambition or initiative since losing my wife. You take care of those rabbits - hear! | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Hey! That truck ain't gonna fix itself, Hoss.
