0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | I got a 1956 235 engine to replace my 1950 216. I followed the list of starting an engine that has sat for a while. The engine fired right up and started pumping oil to the rockers only ran it for about 30 seconds. Decided to do a compression test. The results are as follows #1 cyl. 130 lbs #2 cyl. 150 lbs #3 cyl. 160 lbs #4c. 150 lbs #5 c. 160 lbs #6 cyl. 145lbs
How do these numbers seem to be? Okay to put it in the truck? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | 30 lb differential between high and low? A bit suspect. The engine experts will be along shortly.ðŸ›
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The 'while' sitting probably has to do with the disparity, pot some water in it and warm it up for a while. Se how it improves.
Ed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | They are all so high that I would lose no sleep over the differential.
If you have a running truck, if you have not changed the oil/filter, do it.
I'm a shade tree mechanic - set the timing and carburetor mixture to maximum vacuum using a vacuum gauge at the wiper-vacuum port on the intake manifold. Adjust the idle speed at a slow/smooth idle (or, 350-500 RPM, if you have tachometer).
Then, go for a long drive. Then, check the compression again. Then, report back here.
Maybe, then, congratulations from all will be in order.
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | I wouldn't be concerned with a difference that small, especially on an engine that's been out of service for a long time. Once you get it tuned well and put an hour of more of running time on it, the differences in compression will probably even out a little. A small error in valve adjustment or slightly sticky piston rings can account for more of a difference than you've got right now. Jerry
