Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (baldeagle, 78buckshot, thekid1950, Rusty Rod, cmayna, tclederman, Oswald), 47 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#1232057 08/26/2017 1:41 AM
I got a 1956 235 engine to replace my 1950 216. I followed the list of starting an engine that has sat for a while. The engine fired right up and started pumping oil to the rockers only ran it for about 30 seconds. Decided to do a compression test. The results are as follows
#1 cyl. 130 lbs
#2 cyl. 150 lbs
#3 cyl. 160 lbs
#4c. 150 lbs
#5 c. 160 lbs
#6 cyl. 145lbs
How do these numbers seem to be? Okay to put it in the truck?
evac34 #1232060 08/26/2017 1:58 AM
30 lb differential between high and low? A bit suspect. The engine experts will be along shortly.🛠
evac34 #1232062 08/26/2017 2:03 AM
Crusing in the Passing Lane
The 'while' sitting probably has to do with the disparity, pot some water in it and warm it up for a while. Se how it improves.
Ed
evac34 #1232063 08/26/2017 2:05 AM
They are all so high that I would lose no sleep over the differential.
If you have a running truck, if you have not changed the oil/filter, do it.
I'm a shade tree mechanic - set the timing and carburetor mixture to maximum vacuum using a vacuum gauge at the wiper-vacuum port on the intake manifold. Adjust the idle speed at a slow/smooth idle (or, 350-500 RPM, if you have tachometer).
Then, go for a long drive.
Then, check the compression again.
Then, report back here.
Maybe, then, congratulations from all will be in order.
evac34 #1232080 08/26/2017 2:50 AM
I wouldn't be concerned with a difference that small, especially on an engine that's been out of service for a long time. Once you get it tuned well and put an hour of more of running time on it, the differences in compression will probably even out a little. A small error in valve adjustment or slightly sticky piston rings can account for more of a difference than you've got right now.
