6 members (Jon G, baldeagle, RLB, frogfarmer, ndkid275, Hush), 74 guests, and 2 robots.
Topics128,087
Posts1,055,974
Members48,430
#1231809 08/24/2017 4:19 PM
Is this the governor that the carburetor is sitting on?
ID tag on my 42 1.5 ton has a MPH rating "with governor" and a "without governor" rating.
https://goo.gl/photos/5dFwPPdXtwFUkkyM9
https://goo.gl/photos/VwLM4Nzk5iT2Prfr7
GreggE #1231811 08/24/2017 4:37 PM
Yes, that's what it appears to be. Does the vacuum line attached to the unit under the carburetor go to the distributor? Most governor-equipped engines use a special distributor with manifold vacuum plumbed to a speed sensor that controls the throttle position.
GreggE #1231813 08/24/2017 4:42 PM
Yes there is a line that runs to the Distributor Thank you .
Thank you for the manual page also. I will try and adjust it this weekend. Top speed is 40 MPH. I would like to see if I could squeeze another 5 mph out of it.
GreggE #1231883 08/25/2017 12:12 AM
Years ago many people would take the throttle plates
off the governor then re-install the governor back up
so it appeared that the unit still worked.
That's what was done to my son's 1946 2 ton.
Jeffrey
GreggE #1231971 08/25/2017 4:36 PM
I don't see a governor in your image, just the bottom casting of your carburetor. If the governor is still there, it should look like or be reminiscent of the one Tim posted.
Lots more pictures
