| | | Forums66 Topics128,088 Posts1,056,125 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | Yes, that's what it appears to be. Does the vacuum line attached to the unit under the carburetor go to the distributor? Most governor-equipped engines use a special distributor with manifold vacuum plumbed to a speed sensor that controls the throttle position. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2017 Posts: 55 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 55 | Yes there is a line that runs to the Distributor Thank you . Thank you for the manual page also. I will try and adjust it this weekend. Top speed is 40 MPH. I would like to see if I could squeeze another 5 mph out of it.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Years ago many people would take the throttle plates off the governor then re-install the governor back up so it appeared that the unit still worked.
That's what was done to my son's 1946 2 ton. Jeffrey | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I don't see a governor in your image, just the bottom casting of your carburetor. If the governor is still there, it should look like or be reminiscent of the one Tim posted. | | |
