1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1231219 08/21/2017 12:35 PM
good morning to all,
recently my son and i noticed air bubbles in the fuel filter in our 1937 chevrolet carryall with a 216 motor. the tank was redone a couple years ago, the lines we replaced from tank to fuel pump then from fuel pump to glass bowl fuel filter. the problem is when we go uphill, the suburban starts to stutter and it stops. we can start it but it takes a few cranks. any advice?
we checked and tightened the fuel lines
some people said to replace fuel filter, fuel pump some even said this was normal.
thanks in advanced.
here is a video of fuel filter
1937 Chevrolet Carryall http://www.oldmemoriescc.com/images/blvdbombs/images/IMG_6465_JPG.jpg
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
When was the last time the filter element was replaced? Maybe partially clogged from stuff in the reconditioned tank. Just thinking out loud.🛠
i will replace that tonight because i remember a while back crud floating in it. i took the filter apart but maybe internally there is something in there i will replace the unit as i bought one saturday thanks
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
You are sucking air from somewhere. If there is an obstruction in the gas tank or in the line before the fuel pump, a good fuel pump will suck air from a fitting which will not leak gas.
