0 members (), 108 guests, and 2 robots.
Topics128,035
Posts1,055,560
#123031 11/14/2006 8:16 PM
Finally got the computer and the digital camera to cooperate and got these pics to you guys. The paint turned out beyond my expectations so I'm happy. Check out the first shot of ingredients.
Dan
http://rides.webshots.com/photo/2750634870071274430qzyNpf
#123032 11/14/2006 9:21 PM
That looks really really good!!!Good choice of 12oz.cans. Does that go down first or last?
The crew that works on the \'42 --Sara, Hannah and Abby
#123033 11/15/2006 6:26 AM
Nice Job. You are cruising right along.
#123034 11/20/2006 2:49 AM
It looks great! Which white is that? I was planning to use the BPS paint & hardener, but my Tractor Supply store dropped it. I did one running board and my headligh cans so far, just experimenting. I like their paints. What did you use for primer? How did you keep from making the whole place white?
MV - <Paint Noob>
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
#123035 11/20/2006 3:46 PM
Thanks all!!!!
Dad6x 12 oz all the time! Too much really. MV I used a multitude of primers but gray primer prior paint was a Crossfire acrylic primer-surfacer from
NAPA(Martin-Senour budget line). BPS paint was International white reduced about 15% with hardener. Paint was shot with a HLVP gun with 10 psi at the gun. Overspray wasn't to bad. Paint laid really flat. You could slow the gun down and watch the paint melt together. I was lucky to have all the elements come together at the same time as I usually don't have that luck. I still got some dust and 1 minor run but they buffed out.
The input received from this site has helped me tremendously. Thanks all
Dan
