9 members (Hotrod Lincoln, sron48, FAST55, Uncles51, gswbbc, Hanks custodian, 32Fordpuchoptop, Joe W, 1 invisible),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Finally got the computer and the digital camera to cooperate and got these pics to you guys. The paint turned out beyond my expectations so I'm happy. Check out the first shot of ingredients. Dan http://rides.webshots.com/photo/2750634870071274430qzyNpf | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | That looks really really good!!!Good choice of 12oz.cans. Does that go down first or last? | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Nice Job. You are cruising right along. | | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | It looks great! Which white is that? I was planning to use the BPS paint & hardener, but my Tractor Supply store dropped it. I did one running board and my headligh cans so far, just experimenting. I like their paints. What did you use for primer? How did you keep from making the whole place white? MV - <Paint Noob> | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Thanks all!!!! Dad6x 12 oz all the time! Too much really. MV I used a multitude of primers but gray primer prior paint was a Crossfire acrylic primer-surfacer from NAPA(Martin-Senour budget line). BPS paint was International white reduced about 15% with hardener. Paint was shot with a HLVP gun with 10 psi at the gun. Overspray wasn't to bad. Paint laid really flat. You could slow the gun down and watch the paint melt together. I was lucky to have all the elements come together at the same time as I usually don't have that luck. I still got some dust and 1 minor run but they buffed out. The input received from this site has helped me tremendously. Thanks all Dan | | |
