0 members (), 137 guests, and 2 robots.
Topics128,211
Posts1,057,475
Members48,473
I'm getting ready to cinch down my steering wheel, and wondering whether the horn contact where it rides on the mast bearing ring should have a dab of dielectric grease, or should it be run dry? The brush end of the original horn contact that I pulled out of the steering wheel was dry and had some pretty heavy wear...
~ Dave
I think a little dab will do it.......when they are "tight" or dragging hard, you can hear it grinding sometime when you turn the wheel. But in a loud truck no one will notice!!
Glad I asked...thanks Chipmunk
~ Dave
Just make sure that the surface which the brush rides on is very clean and very smooth and it will last another 60+ years without any lube.
