| | | Forums66 Topics128,203 Posts1,057,414 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | I'm getting ready to cinch down my steering wheel, and wondering whether the horn contact where it rides on the mast bearing ring should have a dab of dielectric grease, or should it be run dry? The brush end of the original horn contact that I pulled out of the steering wheel was dry and had some pretty heavy wear...
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I think a little dab will do it.......when they are "tight" or dragging hard, you can hear it grinding sometime when you turn the wheel. But in a loud truck no one will notice!! | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Glad I asked...thanks Chipmunk
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Just make sure that the surface which the brush rides on is very clean and very smooth and it will last another 60+ years without any lube.
