1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1229905 08/13/2017 9:13 PM
I have a 49 suburban that did not have the headlight trim ring on it when purchased. I've driven like that for couple years but decided to put on the trim rings. One side went on w no issues but bucket on driver side doesn't have the slot for the top clip to fit in. I'm thinking somewhere in its past the PO must have swapped out for a later bucket. Any suggestions other than find the correct bucket on how to attach the ring?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
Sir Searchalot
Sir Searchalot
make a slot
Could yours possibly be on upside down?...probably not. Its been a long time since I put mine in.
Thanks for replies. After I posted I took it apart to to see if I could figure out how to mount the ring . Its not upside down and definitely not a 50s bucket. so will post in Swapmeet or go to local swaps to find one. For now it looks like a one eyed bug.
This is old post but if you have same issue I was able to buy a repop on eBay for ant $35
