1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | I have a 49 suburban that did not have the headlight trim ring on it when purchased. I've driven like that for couple years but decided to put on the trim rings. One side went on w no issues but bucket on driver side doesn't have the slot for the top clip to fit in. I'm thinking somewhere in its past the PO must have swapped out for a later bucket. Any suggestions other than find the correct bucket on how to attach the ring?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Could yours possibly be on upside down?...probably not. Its been a long time since I put mine in. | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Thanks for replies. After I posted I took it apart to to see if I could figure out how to mount the ring . Its not upside down and definitely not a 50s bucket. so will post in Swapmeet or go to local swaps to find one. For now it looks like a one eyed bug.
| | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | This is old post but if you have same issue I was able to buy a repop on eBay for ant $35
