4 members (Wayne67vert, Southerntruck, Guitplayer, Napco Man), 106 guests, and 2 robots.
Topics128,093
Posts1,056,477
Members48,444
#1229727 08/12/2017 3:15 PM
does anybody know if you can turn a front axle around and run it backwards to use rack and pinion ......tie rods are on the back of axle and rack and pinion is in the front
Why don't you use a rear steer rack, like a Ford T-bird rack? The make a kit for the 55-59 trucks and they also have the tie rod to the rear, maybe it could be adapted for your truck???
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Also, make sure the rack is mounted to the axle, otherwise you'll have terrible bump steer issues!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
The steering arms are just bolted to the spindles, can't you just swap them and leave the axle alone?
How do you plan on making the connection to the rack when the axle and rack move and the steering column doesn't?
Buy some good insurance- - - - -a life policy for yourself and a high-dollar liability policy for the people you're about to run over. R&P on a straight axle is a disaster looking for somewhere to happen.
