1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1229302 08/09/2017 7:27 PM
Hello all, I have a 235 six in my 1936 chevy pickup w/a rochester 1b carb & I'm having vacuum issues; I set the timing to spec & when I checked the vacuum the needle stays in the red & says late ign timing or leak at intake manifold, I then sprayed all connections w/soap (as well as the line coming from the carb but found no bubbles (with line disconnected & plugged) I then removed carb & checked the ceramic spacer & it looks new; there is a hole in the manifold where the carb bolts but is blocked by the spacer. I'm out of ideas, Any suggestins? All help is appreciated. Thx Richard. PS, When I reconnected the line to vacuum advance it advanced the timing.
bebop40 #1229312 08/09/2017 8:33 PM
Note added later: only do this after reading the post/suggestions/question in the message below.
Hello, bebop40,
Try slighting opening an unlit propane torch around the base of the carburetor and all intake lines/parts while the engine is idling. If the idle speed changes, you have found a leak.
bebop40 #1229319 08/09/2017 9:20 PM
How is the engine running besides the vacuum problem? If you advance the timing, can you get vacuum?
Are you reading the vacuum at the manifold or carburetor?
You may have the gauge plugged into a ported vacuum port instead of full time vacuum, is the port above or below the throttle blade?
Joe
Joe H #1229325 08/09/2017 10:31 PM
Hello Joe, The engine runs fairly well but feels like something is holding it back, not real smooth, I have a vacuum port at the intake manifold that is plugged off; I diconnected the line that comes fron the carb (above the throttle plate) & goes to thevacuum advance. no the vacuum does not increase when raising the rpms, upon reconnecting the line at the vacuum advance pthe distributor immediately advanced at idle.
bebop40 #1229329 08/09/2017 10:48 PM
bebop49,
I think the vacuum above the throttle plate (ported vacuum?) is not useful for obtaining vacuum at normal idle speed.
tclederman #1229381 08/10/2017 2:36 AM
Can I run full vacuum straight off the intake manifold to the vacuum advance?
bebop40 #1229391 08/10/2017 3:07 AM
You can do it, but you probably should not do that?
bebop40 #1229397 08/10/2017 4:41 AM
Originally Posted by bebop40
.... I then sprayed all connections w/soap (as well as the line coming from the carb but found no bubbles [....] there is a hole in the manifold where the carb bolts but is blocked by the spacer [....] upon reconnecting the line at the vacuum advance the distributor immediately advanced at idle.
vacuum doesn't blow bubbles, it sucks, need to use the propane as Tim suggests - instead of reconnecting it, try just plugging it off, which may be what you're doing connecting it with that hole blocked by the spacer, will prolly act the same as "reconnecting" it
bebop40 #1229499 08/10/2017 8:34 PM
Hello again everyone, I tested the manifold & carb w/the propane torch & no increase😖 in rpms; however connecting the vacuum gauge to the line that goes to the v advance & manually raising the rpms by the throttle, the needle moved up to about 22 degrees & on deacceleration dropped back to the red zone. 😖. any more ideas?
bebop40 #1229500 08/10/2017 8:52 PM
Does your carburetor insulator look like this (it is usually bakelite, not ceramic)? Ceramic would be better than metal (I have seen metal "insulators").
Does your insulator have slots as shown in the image above?
Is one of the slots under an opening in the base of the carburetor?
tclederman #1229538 08/10/2017 11:34 PM
Yes the insulator looks like that. It is bakelite, not ceramic (my mistake) There is a gasket that sits on the manifold under the insulator & also a gasket between the insulator & the carb.
bebop40 #1229542 08/10/2017 11:45 PM
Are the slots in the gaskets and spacer aligned with the port on the bottom of the carburetor?
bebop40 #1229543 08/10/2017 11:48 PM
H Online: Content
Connect the vacuum gauge to the port in the side of the intake manifold directly below the carburetor mounting flange. If there isn't a vacuum nipple there, install one. You're wasting your time (and ours) trying to use distributor vacuum for tuning.
Joe H #1229546 08/11/2017 12:26 AM
"Does your insulator have slots as shown in the image above?
Is one of the slots under an opening in the base of the carburetor?"
ditto ditto
bebop40 #1229556 08/11/2017 1:44 AM
Adding to the confusion.
ALWAYS connect the vacuum gauge to the port below the carburetor on the intake manifold. Using the ports on the carburetor give incorrect readings.
I have not had good results using propane to check for intake leaks. I use carb cleaner or brake cleaner.
Use of a vacuum gauge for diagnostics. http://performance-diy.blogspot.com/2012/04/vacuum-gaugereading-and-interpretation.html
Using a vacuum gauge for timing & tuning. I quit using a timing light on these engines years ago. http://automotivemileposts.com/garage/v2n8.html
Fred
52 3600
69 C-10
bebop40 #1229605 08/11/2017 12:41 PM
H Online: Content
Fred, I'm interested in hearing about how you are checking the operating range of the centrifugal and vacuum advance with a vacuum gauge? My delay flash timing light does a good job of that.
