1 members (baldeagle),
91
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 48 | Hello all, I have a 235 six in my 1936 chevy pickup w/a rochester 1b carb & I'm having vacuum issues; I set the timing to spec & when I checked the vacuum the needle stays in the red & says late ign timing or leak at intake manifold, I then sprayed all connections w/soap (as well as the line coming from the carb but found no bubbles (with line disconnected & plugged) I then removed carb & checked the ceramic spacer & it looks new; there is a hole in the manifold where the carb bolts but is blocked by the spacer. I'm out of ideas, Any suggestins? All help is appreciated. Thx Richard. PS, When I reconnected the line to vacuum advance it advanced the timing. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Note added later: only do this after reading the post/suggestions/question in the message below.
Hello, bebop40,
Try slighting opening an unlit propane torch around the base of the carburetor and all intake lines/parts while the engine is idling. If the idle speed changes, you have found a leak.
| | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | How is the engine running besides the vacuum problem? If you advance the timing, can you get vacuum?
Are you reading the vacuum at the manifold or carburetor?
You may have the gauge plugged into a ported vacuum port instead of full time vacuum, is the port above or below the throttle blade?
Joe | | | | | Joined: Apr 2007 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 48 | Hello Joe, The engine runs fairly well but feels like something is holding it back, not real smooth, I have a vacuum port at the intake manifold that is plugged off; I diconnected the line that comes fron the carb (above the throttle plate) & goes to thevacuum advance. no the vacuum does not increase when raising the rpms, upon reconnecting the line at the vacuum advance pthe distributor immediately advanced at idle. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | bebop49,
I think the vacuum above the throttle plate (ported vacuum?) is not useful for obtaining vacuum at normal idle speed.
| | | | | Joined: Apr 2007 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 48 | Can I run full vacuum straight off the intake manifold to the vacuum advance? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You can do it, but you probably should not do that? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | .... I then sprayed all connections w/soap (as well as the line coming from the carb but found no bubbles [....] there is a hole in the manifold where the carb bolts but is blocked by the spacer [....] upon reconnecting the line at the vacuum advance the distributor immediately advanced at idle. vacuum doesn't blow bubbles, it sucks, need to use the propane as Tim suggests - instead of reconnecting it, try just plugging it off, which may be what you're doing connecting it with that hole blocked by the spacer, will prolly act the same as "reconnecting" it Bill | | | | | Joined: Apr 2007 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 48 | Hello again everyone, I tested the manifold & carb w/the propane torch & no increase😖 in rpms; however connecting the vacuum gauge to the line that goes to the v advance & manually raising the rpms by the throttle, the needle moved up to about 22 degrees & on deacceleration dropped back to the red zone. 😖. any more ideas? | | | | | Joined: Apr 2007 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 48 | Yes the insulator looks like that. It is bakelite, not ceramic (my mistake) There is a gasket that sits on the manifold under the insulator & also a gasket between the insulator & the carb. | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | Are the slots in the gaskets and spacer aligned with the port on the bottom of the carburetor? | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Connect the vacuum gauge to the port in the side of the intake manifold directly below the carburetor mounting flange. If there isn't a vacuum nipple there, install one. You're wasting your time (and ours) trying to use distributor vacuum for tuning. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Are the slots in the gaskets and spacer aligned with the port on the bottom of the carburetor? "Does your insulator have slots as shown in the image above? Is one of the slots under an opening in the base of the carburetor?" ditto ditto
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Fred, I'm interested in hearing about how you are checking the operating range of the centrifugal and vacuum advance with a vacuum gauge? My delay flash timing light does a good job of that. Jerry
