2 members (delky, MickeyP), 101 guests, and 1 robot.
Topics128,131
Posts1,056,723
Members48,454
#1228817 08/07/2017 2:22 AM
I have a brand new rebuilt carb. Seems to leak no matter how tight the screws are. Saw lots of pictures of other trucks with the same leak.
Does anyone have an answer for this?
Don
Can’t begin to tell you how much I hate the name Stovebolt.
You may want to check your float.
1950 3100 5 Window
http://imgur.com/a/DAVYB
Riding in the Passing Lane
Like Bruce says. Your float level may be too high. Some seepege is routine on these carbs although not normal. These "brand new rebuilt" carbs are usually not right. You are generally better off getting an old timer to put a kit in the original carb.
1972 Chevy c10 Cheyenne Super
My past problem with a Rochester turned out to be to much fuel pressure, added an adjustable pressure regulator from Napa, set at about 3 psi, problem solved. An inline pressure gauge is a good ideal also.
1946 1/2-Ton Chevy
Got to admit. I have plenty of pressure from the pump.
Not ready to tear into a newly rebuilt after only 3 weeks.
Mine looks like others at this point.
Thanks Don
I had a similar problem with mine (56 with 235) and I thought the fuel was coming from between the top of the bowl and the cap at the front of the carb. I also rechecked the float level, and also put some thread tape on the adapter that threads into the carb that then accepts the fuel line (I did not tape the fuel line, should not need to). Though I am not sure, I believe that that was where my leak was coming from. Any way, no more leak. Be carefull tightening down the top screws too much, you may end up putting a bend in your top plate. If it is nice and flat, then just snug should be enough.
Lee.
1956 Chevy 3200, 235 w/3 speed
Thanks. I'll look closer at the line connection.
