Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (carbking, 2-Ton, baldeagle, Shaffer's1950, Hanks custodian), 33 guests, and 3 robots.
Topics128,005
Posts1,055,254
Members48,418
#1228622 08/05/2017 9:42 PM
I'm installing glass and gaskets in most of the windows of my 1954 gmc and I'm not sure how to secure the new window channels in the doors.
The old channel has clips stuck to it somehow. Do I need to reuse the clips on the new channel?
Here's a picture to try and help explain.
[IMG]http://i1147.photobucket.com/albums/o546/Adam_Jerstad/Mobile%20Uploads/0804172146.jpg[/IMG]
1954 GMC 350-27
Adam, in the end I have used some emblem/weather stripping adhesive and some real small sheet metal screws in strategic places like the corners and have never had a problem......... I'm not sure now days but there use to be a vendor that had the "real deal".
That seems like an easier solution. Maybe I'll try and find the brackets. If they're cheap it might be worth a shot.
1954 GMC 350-27
I did the same thing.
There are places where theres 2 layers of sheet metal in the frame.
I used small black metal metal assembly screws like in vcr and camcorders.
Drilled and tapped holes.
Worked well and invisible.
Give me ambiguity
or give me something else
The aftermarket brackets are not made of the same kind of steel as the originals and are therefore difficult to make usable. Another issue is that it is difficult to attach the brackets to the channels. They have two prongs on them which are installed like a staple.
It is also difficult to reuse the original brackets because the metal is stiff and brittle, making it hard to straighten the prongs out.
It is much easier to hold the channels in place with tiny self-tapping screws, and you only need a few of them to keep the channels in place.
Carl
Thanks for the input! That's the route I'll go, and hopefully the truck will be weather tight soon!
1954 GMC 350-27
