1 members (baldeagle), 76 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#122693 10/29/2006 4:39 PM
Simple question!!! What has anyone found to be the best tar removal with out damaging the paint.. Its hardened real good. Any Ideas
#122694 10/29/2006 4:41 PM
WD-40
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#122695 10/29/2006 4:48 PM
gasoline will take it off too but you will most likely have to repolish
#122696 10/29/2006 4:56 PM
agree with Bruce, wd-40 works well,you can buy other stuff but the 40 works well
Redryder pix
My Hotrod
#122697 10/29/2006 5:29 PM
I'll 3rd the WD40, diesel works also but much more smelly & messy. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#122698 10/29/2006 10:13 PM
Well I tried the wd40 no go. Remember this tar has been on for a while when i got the truck early this year... its not soft....Peter
#122699 10/30/2006 12:46 AM
You may want to try the more aggressive gas or diesel using outside or with good ventilation. You don't mention where the tar is but I am guessing on a vertical surface. WD-40 would "work" on the tar if a horizontal surface where it could be allowed to soak. Wash thoroughly with soap and water and wax/polish if you get it off with anything harsh. Are you sure it is indeed tar?
Bruce
#122700 10/30/2006 1:48 AM
On one road crew truck I bought, I used diesel fuel sprayed from a garden sprayer & a cheap plastic putty knife-but do not smoke, Brian
#122701 10/30/2006 3:51 AM
Well its lumpy and black it must be tar. Peter
#122702 10/30/2006 5:14 AM
Junior Member
Junior Member
Try softening it up with a hairdrier first,and before it cools soak it with the WD-40 and rub it with an old wash cloth or anything terrycloth so as not to scratch anything.
Rezman
Snapoff brand tools
1948 Chevy 6400
1949 Chevy 4400 (parts truck)
#122703 10/30/2006 7:41 AM
You can use mineral spirits if you have a good factory paint job or a well cured 2k paint job, but try it on an invisible area first. I used it to remove graffiti on one of my previous cars, worked great. Rinse it off quickly because it will eventually soften paint.
Paint & Body Shop moderator
#122704 11/06/2006 3:44 AM
Try some mayo from the kitchen just put it on and let is set a bit then wipe it off. Works on fresh tar and tree sap but have never tried it on old tar stains.
Maybe worth a shot.
1947 Chevrolet "under construction"
#122705 11/06/2006 8:03 PM
Mayo? See, I keep telling my wife not to put the stuff on our food!
#122706 11/06/2006 9:30 PM
Acrysol, the best darn tar remover there is. We use it on new cars and it won't harm the finish. There are several distributors but it can be bought at most auto parts houses. The stuff we use is by Kent.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
