Brrrr
place holder
8 members (78buckshot, Thom75, Mike B, Lightholder's Dad, UtahYork, cmayna, tclederman, 1 invisible), 186 guests, and 4 robots.
Topics128,271
Posts1,058,415
Members48,485
trying to remove the hood part that the latch part attachs to the hood held in with small clutchhead screws 2 are stripped and there flush screws no shoulder to grab any thoughts on how to get them out????
Drill the head, retap later.
grind the heads off enough to get the latch plate up and then you can soak the broken screws a little and then use a pair of vice grips on the "nubs" that are left and twist them out.
Gonna take a lot of sheet metal with that grinding. These are countersunk screws.
drill the heads leave the stud part to grab later
Apprentice
Apprentice
If you drill out screws with left hand bits a lot of them grab and come all the way out.
Thanks, Kelly
53 3100
http://www.cravy.com/53-3100/LadyAfterRats.jpg
If you have a Dremel tool, sometimes you can grind a slot in the head and use a flat blade screwdriver to get them out.
Keith
If it were easy they'd have grade schoolers doing it!
When I bought the truck the PO gave me the 4pc Blue handle clutch head driver set that the vendors sell. All of them fit very loosely in the slots, is this normal for this type of screw?
I've also noticed that the 4 hex drivers that I bought from McMaster Carr also fit loosely, must be the screw butterflies were made pretty sloppy.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
