0 members (), 117 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#122547 10/21/2006 4:49 PM
Well guys I hope that I am not sorry for not ordering the glass compliet with frames. I can't seem to get the new glass and seal into that little chanal frown . So whats the trick? eek Help Me :p
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Tab Offline
What truck do you have? I did the job on my 62 but just had to figure it out through trial and error.
delete my account and pictures
It's A 56 6100. There is pic's of it in Big Bolts
user
Tab Offline
HevyHauler: Just start taking things apart and see what happens. Do one side then the other in case you forget where things go. lol...
Thank you Tab, but I Already have the driver side apart. Working on putting the frame around the new glass. There is a seal tape that gets pressed in to the frame channal with the new glass. This is so tite I am afraid of braking the glass. Now I see why all the catalogs offer preassembled door glass for five times the price.
user
So what's the answer, do the shops have a sprcial press that they press the glass into the channel with? Can one be made up for the home shop, maybe using bar clamps like your would make up a table top out of edge glued solid wood boards? Do they use a lubricant to help it slip into the channel without tearing?
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I don't know Denny. I think I will try some bar clamps,some pieces of 2x4 too spred the load, a little WD-40,and a some heat. I snuck into moma's kitchen put the wind wings in a lasagna pan of water on the stove. When the water came to a boil I used a pair of welding gloves and the old glass slid out like butter. Wish I had used heat for the side glass that was a battle!
user
Tab Offline
I put all of the glass hardware on then reinstalled the glass afterwards. I wouldn't try it fully assembled on my 62 but it might be different on your truck.
