1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Well guys I hope that I am not sorry for not ordering the glass compliet with frames. I can't seem to get the new glass and seal into that little chanal  . So whats the trick?  Help Me :p | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | What truck do you have? I did the job on my 62 but just had to figure it out through trial and error.
delete my account and pictures
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | It's A 56 6100. There is pic's of it in Big Bolts | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | HevyHauler: Just start taking things apart and see what happens. Do one side then the other in case you forget where things go. lol...
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Thank you Tab, but I Already have the driver side apart. Working on putting the frame around the new glass. There is a seal tape that gets pressed in to the frame channal with the new glass. This is so tite I am afraid of braking the glass. Now I see why all the catalogs offer preassembled door glass for five times the price. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | So what's the answer, do the shops have a sprcial press that they press the glass into the channel with? Can one be made up for the home shop, maybe using bar clamps like your would make up a table top out of edge glued solid wood boards? Do they use a lubricant to help it slip into the channel without tearing? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I don't know Denny. I think I will try some bar clamps,some pieces of 2x4 too spred the load, a little WD-40,and a some heat. I snuck into moma's kitchen put the wind wings in a lasagna pan of water on the stove. When the water came to a boil I used a pair of welding gloves and the old glass slid out like butter. Wish I had used heat for the side glass that was a battle! | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I put all of the glass hardware on then reinstalled the glass afterwards. I wouldn't try it fully assembled on my 62 but it might be different on your truck.
