0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#1225180 07/12/2017 7:42 PM
I have difficulty keeping pedal pads on my brake and clutch pedals, especially the brake. It is because I have to bend my leg in a weird fashion to rest my foot on the pedal. It does not sit on square. I am on my second set of pads but they always come off. I had considered gluing them as the PO did but they still slip off. I was even considering drilling two small holes and running small bolts through. Any ideas?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Sedgewick #1225181 07/12/2017 7:46 PM
I'd go with glue. Probably some sort of construction adhesive. That stuff DOESN'T come off. Be sure to get everything clean before attempting to glue the pads on.
Sedgewick #1225194 07/12/2017 8:48 PM
Will give it a go. Thx.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Sedgewick #1225196 07/12/2017 8:56 PM
Second on the construction adhesive. Make sure you let it completely dry before you put any pressure on it.🛠
Sedgewick #1225245 07/13/2017 12:48 AM
I went a different way and used self adhesive non-slip stuff I got at Home Depot. Don't remember the name of it. I think it might be meant for stair treads. I applied to the metal and trimmed to fit. It has held up nicely for several years now. No slipping either when your feet are wet.
Dennis
40 Chevy 1/2 ton
Sedgewick #1225266 07/13/2017 1:58 AM
Why not put two black zip ties on each side of the pads? They might even lay in the grooves. Put the connector on the backside and trim it off flush.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Sedgewick #1225308 07/13/2017 1:11 PM
Dennis is that to replace the pads?
Chuck I like that idea too.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Sedgewick #1225310 07/13/2017 1:18 PM
Bill, I used it instead of the pads.
Dennis
40 Chevy 1/2 ton
Sedgewick #1225362 07/13/2017 8:45 PM
Thanks Dennis. For the moment I have opted to using tie wraps and will see.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Sedgewick #1225601 07/15/2017 3:27 AM
I'm on my second repro set of pads, and this last time I put them on I took my angle grinder and made the metal a little smaller. I also used contact cement. Just noticed the upper right corner of the brake pad was coming slightly loose, the clutch pedal is fine. So, I'll see what develops. If they don't come off I'll just get a little more glue in that upper corner. It seems the repro pads are too small?
Sedgewick #1225622 07/15/2017 12:49 PM
I used electrical tape that I get free somewhere. wink I have lots.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
