0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1224764 07/10/2017 6:01 PM
I've had my 58 step side 15 years and put about 200 miles a yr on it. It has all original parts and a 235 engine. The temp gauge has always worked fine. Past weekend the needle was completely off gauge to low temp side until truck warmed up to 190 degrees ( tested with temp tool) and the needle only registered about 1/4 of gauge up. Usually at 190 it would be just pat 1/2 on gauge. What gives. Any advice? Thanks I'm learning as I find issues to fix.
The 1958 TRI-FECTA
Stepside, Fleetside and Cameo
More Fleetside pix
More Cameo pix
More Apache Stepside pix
sender's going bad, cheap enuff, just replace it
Flexible is most likely correct but I like to know for sure before spending hard earned dollars.
Test: Remove temp sender wire and leave loose. Turn key to run (no need to start). Gauge will go full hot or full cold. Key off, ground sender wire to good ground, key to run. Gauge will go to opposite peg.
If this happens, do as Bill suggest, your sender is bad.
Thanks guys. Should I disconnect wire at sender unit on head or at gauge ?
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
Start at sender. If the test fails, repeat test at gauge to test sender wire.
