0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 80 | The louvers for the fresh air heater on my truck have some holes drilled into them. The replacement panel is real expensive and replaces the entire right side cowl. I am wondering if anyone has smoothed this panel on their truck and still has the louvers laying around? | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | I just finished removing the right side outer cowl panel from my truck. Louvers are in great shape. They're yours if you want them, no charge.
~Ron | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Blake51,
My truck had slightly bent louvers on that panel. I could see no way to repair them that would make them straight and crisp looking as they should be....I replaced the panel!
Any welding in the immediate area of those louvers will surely warp the sheet metal, and maybe the louvers themselves. Be careful!
Stuart | | | | | Joined: Jun 2006 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 80 | atomarc thanks for the advise, that is a very good point. mummdogg I am interested in getting that from you and at least checking it out. send me an email to [email protected] | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | | | |
