0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#1223989 07/05/2017 9:38 PM
The ring and pinion in my 1970 C60 has way too much backlash.(getting worn out) It is a two speed rear with unknown ratio. The carrier has GM right on top of the third. It is an air braked truck. I have no idea if parts can be found for this axle or not. All along I thought it was an Eaton axle. Did GM make their own rear axles in this era?
Please help me figure out what I'm dealing with. The numbers cast into the housing are 387355 and maybe a 1 after that. (not sure on the 1)
rockdog #1224055 07/06/2017 11:53 AM
Crusing in the Passing Lane
There might be numbers stamped into the right side, aft side of axle tube that has additional info.
Ed
rockdog #1224066 07/06/2017 2:14 PM
3B Offline
Hy rockdog, welcome, could you take a couple of pictures and post them here?
rockdog #1224102 07/06/2017 6:13 PM
Is it a vacuum shifted unit, or electric? GM has used both types at different times, and there is a GM corporate axle, and others from different manufacturers. A link to some pictures will be helpful to ID your unit.
rockdog #1224113 07/06/2017 7:58 PM
What engine/trans do you have? Different rears were available with different engine/trans packages.
What's the trucks GVW rating?
Is there a tag inside the glove box door listing the rear size?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
rockdog #1224148 07/07/2017 12:22 AM
Ok I took some pictures. And I'll try to answer the questions. Nothing on the jockey box door for the rear end. Tag on the drivers door says. Rear end 19,000 to 23,000? Gvw on the truck is 32,000. Two speed is electric shift and shift box says eaton on it? But as you can see in the pics. The third has GM cast in the top of the housing. That's what confuses me. Dang can't figure out how to post pics.
rockdog #1224214 07/07/2017 10:09 AM
TGP Offline
You have to post up a Link to your pic's.
Picture's in post's here is not allowed.
Tom
rockdog #1224239 07/07/2017 4:11 PM
Looks like the 1970 C60 Air Brake units were only available with the 427 engine. They had a 6.71/9.14 ratio, 23,000 pound rear with 15x7 rear brakes and either a 9,000 or 11,000 pound front axle.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B #1224259 07/07/2017 7:14 PM
[quote=Mike B]Looks like the 1970 C60 Air Brake units were only available with the 427 engine. They had a 6.71/9.14 ratio, 23,000 pound rear with 15x7 rear brakes and either a 9,000 or 11,000 pound front axle.
Mike B :)[/quote]
Well they made one with a 366. Because I bought it from a small city and the guy who is their crew manager said his dad ordered it new in 70. And that it was all original. :)
Mike B #1224326 07/08/2017 3:10 AM
Mike B smile
What I should have said was IF you ordered the 23,000 pound 2-speed rear it automatically came with the 427 engine and Air Brakes with the ratios listed above.
The 366 with a single speed 17,000 pound rear was the standard issue at 24,000 pound GVW. The 366 could have the optional 17,000 or 18,500 pound 2-speed rears with either Vacuum Over Hydraulic or Full Air brakes.
The 17,000 pound axles are Chevrolet/GM and the 18,500 pound are Eaton.
Sorry for the confusion,
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
