6 members (JW51, 55shaker, moparguy, Cosmo, Gdads51, 1 invisible), 108 guests, and 2 robots.
Topics128,069
Posts1,055,896
Members48,428
#1224075 07/06/2017 3:08 PM
Do you fellas use plumbers tape on brake line fittings?
How about on fuel line fittings?
Thanks.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
If you do use Teflon tape make sure you don't wrap too close to the end of the fitting. You don't want the material getting into the line and plugging it up.🛠
teflon tape on brake fittings - Nope
teflon tape on fuel fittings - Nope
I sometimes use very little of a copper or stainless fittings grease/lubricant.
Thanks for the links so I can see what to use. I really appreciate it!
"Plumber's tape" is the perforated steel strap used to hang pipes.
https://www.amazon.com/LASCO-13-160...;sr=8-1&keywords=plumbers+tape+metal
Teflon thread sealing tape has no place at all on brake line or fuel fittings, which seal at the flare, not the threads. If a pipe-to-flare adapter fitting is used, I'll use paste-type pipe joint compound on occasion, but it the fitting is brass, it's usually better to install it dry, or maybe with a very sparing application of brush-on Permatex sealer like Super 300 to the pipe threads only.
Got it..... Thank you for the clarification. I didn't realize that the threads had zero to do with sealing the fitting.
A little grease or oil on the back of the taper and on the threads doesn't hurt, it will let the fitting tighten up without locking the metals together.
Joe H #1224157 07/07/2017 1:08 AM
Galled threads is usually only an issue with stainless steel fasteners. Plain 'ol steel is usually OK dry, but a little lube won't hurt and like HRL said, brass doesn't need anything.
Man.....if it wasn't for you stovebolters, I would have ZERO chance of finishing my old Suburban.
Windyville1 - i got a huge chuckle out of your last comment! It's so true!
1950 3100 5 Window
http://imgur.com/a/DAVYB
