1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Do you fellas use plumbers tape on brake line fittings?
How about on fuel line fittings?
Thanks.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | If you do use Teflon tape make sure you don't wrap too close to the end of the fitting. You don't want the material getting into the line and plugging it up.ðŸ›
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | teflon tape on brake fittings - Nope teflon tape on fuel fittings - Nope I sometimes use very little of a copper or stainless fittings grease/lubricant. | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Thanks for the links so I can see what to use. I really appreciate it!
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | "Plumber's tape" is the perforated steel strap used to hang pipes. https://www.amazon.com/LASCO-13-160...;sr=8-1&keywords=plumbers+tape+metal Teflon thread sealing tape has no place at all on brake line or fuel fittings, which seal at the flare, not the threads. If a pipe-to-flare adapter fitting is used, I'll use paste-type pipe joint compound on occasion, but it the fitting is brass, it's usually better to install it dry, or maybe with a very sparing application of brush-on Permatex sealer like Super 300 to the pipe threads only. Jerry
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Got it..... Thank you for the clarification. I didn't realize that the threads had zero to do with sealing the fitting.
| | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | A little grease or oil on the back of the taper and on the threads doesn't hurt, it will let the fitting tighten up without locking the metals together. | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | A little grease or oil on the back of the taper and on the threads doesn't hurt, it will let the fitting tighten up without locking the metals together. Galled threads is usually only an issue with stainless steel fasteners. Plain 'ol steel is usually OK dry, but a little lube won't hurt and like HRL said, brass doesn't need anything.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Man.....if it wasn't for you stovebolters, I would have ZERO chance of finishing my old Suburban.
| | | | | Joined: Feb 2004 Posts: 80 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 80 | Windyville1 - i got a huge chuckle out of your last comment! It's so true! | | |
