4 members (Shardean, Tstan7, 2 invisible),
94
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | 1958 gmc 1/2ton truck. What is the bolt size of inner fender down low near the cab. Thanks
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Danny, to be a shop shark you have to know how to figure out a bolt size. Just by eyeballing, you can guess one or two sizes. Like 5/16 3/8...Then try some bolts. Any bolts laying around. By "size" do you mean thread size or length?..or both? You can't be held back waiting for someone to go out and measure, you will never get done. Force yourself to identify the few sizes used on the trucks by eyesite or testing. You need a cheap thread gauge and a set of calipers.... or just 4 different bolt sizes. This is a real basic question. Take this as a constructive recommendation not a dis. You are asking for someone to do more effort than you could do. There will be members with TF that will be kind enough to do it, but it seems a bit hard to understand your position.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Danny, to be a shop shark you have to know how to figure out a bolt size. No, you just need to have posted 100 times. But you're right, it's a pretty basic question. Danny, If your truck is still assembled, check for bolt sizes on a similar installation (maybe the opposite side?)
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There can be basic questions that if you don't know, you want to learn. There are many "basic" questions that I don't know. I've had many TF's but can't remember what size or exactly where you mean.
As you can we are trying to go over all the methods we use in an effort to help. the other bolts.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Don't be too hard on Danny, bartamos. He is a victim of the "New Age" with the "easy way out" internet sourcing. I find myself a victim of it as well. Why work and think when you can make a few key strokes and discover the meaning of life. Before the internet, I had to learn how to fix these old trucks the hard way. While it took longer and was frustrating at times, I did experience a much greater feeling of accomplishment figuring it out by myself. Carl
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Well I was installing the whole front clip on my truck. I had a buddy "help" unbolt& remove it months ago. All the bolts were tossed in one bag. First mistake.2nd mistake was thinking the bolts were coarse thread. So the front clip is held on by national fine thread bolts.7/16th NFT where the grill meets the frame; 3/8 NFT where the top&lower outer fenders bolt on. I was putting coarse stuff where it should have been fine threaded.... Who woulda thought that?  . [quote= Thanks[/quote] Yes I tried various bolts that I had until I had what I thought was "the one" .Turns out it is 5/16thNCT where all others were NFT- I probably should buy a tap&die set.  I posted here vs elsewhere thinking I would get a better more accurate response since I was asking specifically about a 58gmc truck. wasn't looking for "the easy way out"-wanted to hear from people who have "Been there done that" with something in common-  Thanks 4 the advice; the clip is installed.
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Or maybe he's mixed up all his bolts on disassembly or lost them and trying to figure out what is needed to go back. Hoping that someone on here has done it recently and maybe knows off the top. Let's give folks the benefit of the doubt, particularly us Texans who need all the help we can get.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Jul 2004 Posts: 2,986 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,986 | 'Bout time this thread got locked down. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Great job. Glad you got it.
