| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 119 | I just purchased the inside rear view mirror for my 1954 3100. Anyone have any pics of it mounted already? Are there factory holes or must I drill them myself? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There are no factory holes or markings for the inside rear-view mirror in 54/55. I'll look tomorrow in the accessory installation manual to see if there is a template or measurements for the location holes.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | David,
I cannot find a template or instructions for installing the 54/55 interior mirror.
Here is what I have done on two trucks:
- With the windshield and headliner installed, position the mirror arm above the windshield, above/adacent-to the windshield seal, above the middle of the window. - Marked the two hole locations. - Drill through the headliner and the first layer of sheet metal. - Attach the mirror arm (two screws).
I have a cab stripped and could post a photo, so that you can see what you would be drilling through (just ask).
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Photos of 54/55 interior rear-view mirror locations The last two photos show the bare metal in the interior, so you can see the metal you will be drilling into (if your headliner is already in place). | | | | | Joined: Mar 2010 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 119 | Thank you!
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | - Drill through the headliner and the first layer of sheet metal. - Attach the mirror arm (two screws). Use a sharp bit so you don't have to push hard. If you do you're likely to go too far and put a dimple on the roof panel. Along the same line don't use screws that are too long or you risk dimpling the roof that way as well.
| | | | | Joined: Jan 2014 Posts: 10 New Guy | | New Guy Joined: Jan 2014 Posts: 10 | Even though this an older post, I appreciate the info. Easy install with the diagram. For future installers, I did wrap electrical tape about 1/4" up the drill bit so I wouldn't dimple the roof sheet metal. It worked well. Thanks.
Kcd | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'd hate it if that happened.  | | | | | Joined: Sep 2005 Posts: 1 Moderated | | Moderated Joined: Sep 2005 Posts: 1 | Could I get some guidance for installing a rear view mirror in a 51 GMC Cab | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
